Can someone model 467MHz on MOXGEN?
Thank you!
The link you shared has indeed been the closest so far but my results differ.
I suspect it's because you were able to choose vertical polarization (thank you).
I'll be using the specs from your results but for comparison, here are mine.
I'm a little slow and just noticed the vertical polarization I referred to is for the eznec model and has nothing to do with dimensions. So moxgen and the online calculator are showing different results. Hmm
Why moxon? Regular Yagi will better and still small size.
I had good (lucky) success with an 11 meter version I built and I like the 50 ohm feed but yeah, a yagi might make more sense. I'm just having fun building these. I have no formal education on this stuff but I can follow directions. The nanovna sure helps.
Still had to trim it, then added a tail to the reflector. Not afraid to admit no clue as to what that does but it made the Smith chart happy and this little rig just had a good contact on a repeater 28 miles out on that little Retevis and me holding the antenna inside our living room. 3 degrees Fahrenheit here. Sweet.
Reactions: Crawdad and BBI
