CB install problem
  • Thread starter Thread starter Dinocore
  • Start date Start date
D
Dinocore
Guest
I just installed my uniden 501 cb radio in my volvo 240 using the power leads from the radio. I have a magnetic antenna on the back. Radio works fine untill i turn on the engine. then i get a ton of interference. I did some expermenting and determined that if i unplug the antenna the interfearance goes away. need help on what i should do to get rid of the crazy interfearance.
</p>
</p>
I just installed my Titan in my 2002 Chevy Silverado and I have the same problem with what I believe to be fuel pump noise! Never had a problem in the 2000 S-10! The Wilson 1000 MagMount is on the roof of the cab just like the S-10. Wire thru the passenger door like the S-10. Plugged the amp and radio into the extra cig lighter ports like the S-10. Noise goes away when I unplug radio and noise coincides with the sound of the fuel pump running.
CDX 951
Kenworth
Galaxy 77HML,
Astatic 636L Mic.,
Wilson Trucker 2000
Chevy S-10
TitanII Road Pro,KLV-203, Wilson 1000Mag Mount
smalltractorhill
</p>
CDX 951
Kenworth
Galaxy 77HML,
Astatic 636L Mic.,
Wilson Trucker 2000
Chevy S-10
smalltractorhill
</p>
  • @ Geoexplorer69:
  • @ Geoexplorer69:
