Chipswitches???
  • Thread starter Thread starter Hawk
  • Start date Start date
H
Hawk
Guest
To chipswitch or not to chipswitch...........that is the question? You guys that have the chip, is it worth the money for the extra stuff it does. The only plus for me would be that I could use the up-down channel selector on the mic. I don't remember all the extra stuff the chip does for ya and how much does it cost? "Hawk"
DLH Panama City Beach, Fla. CDX 120</p>
I am happy with mine Hawk.
It is a substantial investment but it is worth it to me.
It made my radio much more user friendly as i try to keep my vehicle between the fenceposts.
Chipswitch from www.bills2way.com/
local shop,no shipping
49.95/ Chipswitch
8.00/socket
65.00/ install and audio jack
123.00 total for Bill's
The post below refers to the optional 12 meter coverage.
Bill did that mod also, without me specifically requesting it.
CHIPSWITCH FEATURES
30 MEMORY CHANNELS WITH TEMPORARY CHANNEL LOCKOUT AND REPEATER OFFSETS
The original HR2510 / HR2600 / LINCOLN has basically one memory available to it in the sense that it remembers the frequency you were last on during a power interruption. The CHIPSWITCH supplies you with three groups of MEMORY BANDS. There are now ten (10) user programmable frequency channels available for each MEMORY BAND. You can elect to have repeater offsets to any of the stored memory channels. You are also provided with the ability to lockout any memory channel(s) temporarily during SCAN/SEEK functions.
EXTENDED FREQUENCY COVERAGE (Adding operation at 12 METERS requires additional hardware)
Adding the CHIPSWITCH IC will allow the radio to operate contiguously from 11 through 10 meters. With the installation of an optional 12 METER MODIFICATION KIT, the CHIPSWITCH allows full contiguous coverage from 24.800 to 29.999 MHZ. (12 through 10 Meters)
PROGRAMMABLE SCAN/SEEK FUNCTION
The original HR2510/HR2600/LINCOLN allows you to scan on an arbitrary 'band basis." This new feature allows you to select a range of frequencies for SCAN and SEEK while in band 0, or SCAN/SEEK by memory channels in band 1, 2 and 3. The SCAN feature allows you to set the 'hold-time' (the amount of time the radio waits to resume its scan function after that particular frequency quiets down). The SEEK feature is identical to the SCAN except for when the radio is scanning and detects activity on a frequency, the radio will receive on that particular frequency for a user-programmed length of time before it continues the scan. SCAN and SEEK are completely user programmable for 5 or 10 KHz steps in band 0.
PROGRAMMABLE CHANNEL UP/DN BUTTONS
This provides you with the ability to program the radio's channel up and channel down buttons to change channels/frequencies in any of five (5) different ways. (5 KHz, 10 kHz, Underlined digit, etc.
PROGRAMMABLE MICROPHONE CHANNEL UP/DN BUTTONS
This provides you with the ability to program the microphone channel up and down buttons to change channels/frequencies in any on of eight (<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> different ways.
SPLIT FREQUENCY OPERATION
When enabled, this allows you to transmit on one frequency, and receive on another.
PROGRAMMABLE TRANSMITTER TIMEOUT
This feature provides the radio with a built-in QSO timer. When enabled, it triggers a programmable timer the moment the radio starts transmitting. When the user-programmed length has been achieved, the radio will stop transmitting. To continue transmitting, just release and press the microphone PTT (Push To Talk) Button.
PROGRAMMABLE TRANSMIT FREQUENCY RANGE
This provides you with the ability to program a range of frequencies to operationally transmit on. In this mode of operation, you still have the ability to receive frequencies out of the user-programmed range, but can not transmit on them.
PRIORITY CHANNEL (Requires optional hardware)
Priority channel operations allow you to program any frequency (i.e. home frequency, etc.) and have the HR2510/HR2600/LINCOLN check this frequency while you are on another, at a user-programmed rate. This feature will not function properly without the optional PRIORITY CHANNEL BOARD.
MISCELLANEOUS
The 'SPAN UNDERLINE CURSOR' now has a 'phantom' 4th position (all 3 underline bars) cursor. This enables you to go through the band in 100 KHz increments. This 'phantom' 4th position is indicated by 3 cursors.
The 'SPAN UNDERLINE CURSOR' position and the underlined digit can be moved by pressing both microphone buttons at the same time. (Great for mobile operation)
The button repeat rate is now programmable.
The internal 'button beep' duration is now programmable from 0 to 0.5 seconds.
The 'RPTR' button on the HR2600, when depressed, will transmit the CTCSS tone to open up a repeater station. Repeater offset selection is required when programming memory frequencies.
The HR2510/HR2600/LINCOLN now has two function modes:
OPERATE MODE
This mode is the radio's normal operation mode.
PROGRAM MODE
The front panel controls are used to program information the radio will use during OPERATE MODE (i.e. memory channel frequencies, split channel, scan functions, etc.)
INSTALLATION
As the name CHIPSWITCH implies, the basic modification of the radio is the replacement of the existing UNIDEN microcomputer chip. A person proficient in soldering/desoldering techniques on P.C. boards is qualified. A comprehensive installation manual is provided. No modification to the front panel is required as all the new features are controlled by the existing knob and buttons on the front panel. The optional PRIORITY CHANNEL BOARD and 12 METER MODIFICATION KITS do require minor modifications to the circuit boards.
CDX 864/ northern Ca.
</p>Edited by: <A HREF=http://pub86.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=trailboss1>Trail boss 1</A> at: 2/16/03 11:23:30 pm
I know of a Ebay seller I bought some NOS/NIB radios from that's sitting on five NIB/NOS HR2510's with the Chipswitches installed that he bought new if he still has them but he can't sell to you on Ebay. You have to do a private sale.
Oh yeah,he's wanting $500 a pop.
if the chip is a standard e-prom, a person should be able to read the chipswitch prom in a prom burner, save the file, source out some eproms and re-burn the file to your new eprom
this is pretty standard practice for automobile prom tuning, I do a lot of this for gm vehicles, before 1996 most all of them had a removable prom from their ecm, along with some software I have I can modify all the tables and re-burn the original proms or newer style eproms,, my prom burner is only a 40 pin? so an adapter or different burner would be needed
don't really know if there is much of a demand to go through the work,
I wonder if the original maker of these chipswitch proms was being pressured by someone to stop making them,, because once your set up to burn a prom you could make 100's of proms in a few hours if they all use the same file
So he can avoid a claim and negative feedback???
  • @ heartbreaker3473:
  • @ AudioShockwav:
