I'm hoping some of you can help me cut throught the misinformation that is out there. The way I'll do this is I'll tell you what I've gathered and then let ya'll correct where its wrong. Remember- don't jump down my throat if something I type is wrong, I'm here asking so as to get it right.
The length of 50 ohm coax using a single antenna doesn't (barring a short) affect SWR, however the length of the coax can affect the reading on a meter. The lengths that will give accurate readings are the odd halves (1/2, 3/2, 5/2, etc). If I go with a length in between those, how can I accurately tune my antenna? Put the meter on the antenna end of the coax instead of the radio end? If so, what about the jumper in between the meter and antenna, it is not a 1/2 wavelength?
The reason I'm asking is because I have my radio in my car and the antenna mounted on the trunk. It takes every bit of 18' coax to get in between (it is a big car- crown vic), and that is running straight back down the transmission tunnel. I want to run it to the side of the car and back, but there is just not enough coax. 50' would be too much, hence the question about tuning lengths in between. If I need to go with 50', what do I do with the extra? Putting into a coil isn't good, right?
Shoot me straight, I know you will. Remember, you were ignorant too, before you knew what you know.
