I have a Cobra 142GTL, when you key up and modulate it comes through the speaker like talkback anybody got any ideas what could be causing it?
Well I plugged an external speaker in to see if it did it through the external and it didn't, and when I unplugged the external speaker the problem was no longer thereDo you have another mike to try? The switch in the mike shuts down the speaker while transmitting.
A quick test is to unplug the mike and see if you hear any receiver audio. If you do, this problem lies in the radio and not the mike.
Thanks nomad!! Ordered a couple and will report the results upon the fix.I do remember seeing a disc cap on pin 3 of the mike socket that would do this. Changed it from a .01 or .02, whatever it was to a .001. Fixed the issue.
Taking the pin 3 wire loose from the from the socket would reveal if the socket is involved. And if taking the wire loose doesn't change it, the fault lies elsewhere.
