Hi all, I have a SWR meter / Calibrate problem here : s-meter works fine, but SWR and Calibrate will show the exact SAME readings whatever position I have on the calibrate potentiometer (max reading ca. 3/4 of scale).
Everything worked fine prior the replacement of a few capacitors. I am careful whilst replacing capacitors and maybe i am not enough experienced in reading the schematic, but i have not found the SWR / calibrate circuitry to be on the path of electrolytic caps. Maybe a wrong solder joint somewhere?
Any hint would help find out what could have gone wrong meanwhile.
Thanks for your help! 73, Chris
