After about 3 months of parts sitting I found time and weather that worked for me.
Yup..time to drill a hole in the roof and install my NMO Breedlove mount!
Had to basically take all the rear interior panels off the get the headliner to drop enough to not punch through. I used a Harbor Frieght step bit. It worked but I should have gotten a better bit. It took some pressure to drill to 5/8”.
My son helped to hold the headliner while I drilled. Ok hole is good and centered. Make sure to triple check your measurements!! Could not install exactly in center of roof because of cross brace. So basically the exact same spot I had the magmount on.
My Dad was a welder and metal guy. He’s in his 80’s but still likes to get involved. I measured a 14ga stainless steel plate for support under the mount inside the truck. He cut and rounded the corners for me. Good job Pops!!!
Installed the coax and tried her out. SWR...1.1 across the band! 1.3-4 when amp is on. Super happy with the results! All that bonding sure paid off. Hearing more distant stations and noise floor is lower. Just need to make a gasket to replace Sirio gasket.
So it’s the NMO to adaptor to antenna.
A shot of the interior:
It’s real stable if I whip the whip back and forth. Hardly any flex. Even with the 3” mount. Took a drive and no issues.
Thanks to all that helped me along through this build up to this point!!! All that advice that was given is golden!!
I’ll put mine in next week (Ha!).
Looks great! I’ve no doubt it will perform well.
Shots of how coax run (and power run) will be nice to see.
The POWERWERX 12V Distribution Panel I recently installed is a NICE piece. More so than the SOTABEAM box it replaced (buss bar vs circuit board).
Anderson PP a great help in set up and take down. Changing something doesn’t involve losing nuts & washers.
Going to use an Isolator (feedpoint CM Choke)?
What post #s was the RF Bond story?
