Cobra 2000 Audio Help Air Blowing Sound Through Speaker
HavaV10
228
44
38
58
Lake Havasu City, Arizona
Got a old Cobra 2000 GTL late 1978 model. Been fully electrolytic recapped. It has a low air blowing sound coming through the speaker when the volume is turned all the way down. I attached a video explaining this issue with it. The sound is still there even with squelch turned up and rf gain fully counterclockwise. The 2000 used to have a roger beep board in it. I removed that and corrected the wiring to the mic jack but maybe I have the wiring wrong cause this problem. It used to receive with the mic unplugged. Thanks for any help or suggestions.
Mike
I start by unsoldering the center leg of TR43. If you hear no change, the culprit is an early-production TA7222P, probably a "P" and not the later "AP" version. Can't see that ID on the chip until it's removed anyway. If this kills the noise, replacing TR43 is the next thing to try.
This symptom seems to come up mostly in pre-1980 radios.
