Cobra 2000gtl clarifier help/problem
dss56
Well-Known Member
Sep 27, 2010
434
125
53
58
course. fine
removed the brown from fine vl.
remover yellow wire from the cvl and to ground
removed D52/D44
RED WIRE TO 8V CONSTANT.
RADIO WILL NOT ALIGN FOR TRANSMIT/RECEIVE. COUNTER SHOWS 1 frequency and will transmit off frequency.
tried a few different ways and same problem.
So i put it all back together stock and is fine.
Havent done 1 of these in a long time.
Any suggestions on what might cause the transmit and receive will not align?
thanks
Nomadradio.
As I posted that I removed the brown wire from the Fine pot and I did not do that.
Thought I did but I now removed and all is good lined right up.
thanks for the reply d52 and d75 are all set.
Reactions: AudioShockwav
