Retevis is giving away ANOTHER RA89R Radio for Independence Day! Click Here for more info!
I'm looking for a Cobra 25LTD with the TDA2003 chip I need the part # for the pll chip IC3 cant seem to find a newer schematic with the part # for the PLL
I looked on the schematic for the part number. I haven’t tried looking for the PLL itself. I had to have some of those 2003 audio chips though, they were fun to find. I imagine the PLL might be as well, don’t know.
I have on order a 9106 pll and hope it is a replacement for the 25ltd pll should have in a few days.
On to my next problem. Same radio its a cobra 25ltd newer version with the TDA2003 audio chip. I did replace the pll with 1 from another radio and radio works so pll bad and 1 is on order.
The problem I'm having is the TX audio and no pa audio.
Radio receives ok no audio problem.
On transmit there is very low audio I have to scream into the radio to get an external modulation meter to move.
I put a radio close to the 25ltd and good signal but low audio.
On the watt/mod meter the watts are around 3 watts but no audio out.
I replaced the TDA2003 with a know good one and same problem low modulation.
So I replaced some caps in the area and also checked some electro/caps most seem good.
Any suggestions board layout and schematic attached
I'd look into replacing C47 (inverted feedback loop cap at TDA2003) - and C57 the audio out cap...cheap insurance
But if you get good carrier - when you have to replace the Audio Chip - you usually have to replace what took it out else you'll be right back at it again - usually the audio output cap that goes to the modulation transformer needs to be replaced too, that is usually C57
When you have low PA output too - and the RX in the speaker doesn't sound good - usually again, back to C57 - about a 330uF on up to 470uF 25V cap is used you can TRY TO get away with a 16 Volt Rated cap here at C57, but you may wind up replacing that again soon enough.
The American Radio Relay League (ARRL) is the national association for amateur radio, connecting hams around the U.S. with news, information and resources.
