A Winner has been chosen for the 2026 July 4th Retevis RA89R Giveaway! Click Here to see who won!
I'm looking for a Cobra 25LTD with the TDA2003 chip I need the part # for the pll chip IC3 cant seem to find a newer schematic with the part # for the PLL
I looked on the schematic for the part number. I haven’t tried looking for the PLL itself. I had to have some of those 2003 audio chips though, they were fun to find. I imagine the PLL might be as well, don’t know.
I have on order a 9106 pll and hope it is a replacement for the 25ltd pll should have in a few days.
On to my next problem. Same radio its a cobra 25ltd newer version with the TDA2003 audio chip. I did replace the pll with 1 from another radio and radio works so pll bad and 1 is on order.
The problem I'm having is the TX audio and no pa audio.
Radio receives ok no audio problem.
On transmit there is very low audio I have to scream into the radio to get an external modulation meter to move.
I put a radio close to the 25ltd and good signal but low audio.
On the watt/mod meter the watts are around 3 watts but no audio out.
I replaced the TDA2003 with a know good one and same problem low modulation.
So I replaced some caps in the area and also checked some electro/caps most seem good.
Any suggestions board layout and schematic attached
I'd look into replacing C47 (inverted feedback loop cap at TDA2003) - and C57 the audio out cap...cheap insurance
But if you get good carrier - when you have to replace the Audio Chip - you usually have to replace what took it out else you'll be right back at it again - usually the audio output cap that goes to the modulation transformer needs to be replaced too, that is usually C57
When you have low PA output too - and the RX in the speaker doesn't sound good - usually again, back to C57 - about a 330uF on up to 470uF 25V cap is used you can TRY TO get away with a 16 Volt Rated cap here at C57, but you may wind up replacing that again soon enough.
