Need to put a little amp behind a stock cobra for a friend running a base radio. My friend is on a limited budget on his radio set-up he has a stock 29 lx and a Imax antenna and a 50 amp power-supply. I said any of the class AB-1 amps 150$ is the budget. RM Italy or Palomar mosfet small TNT what will work good with a stock radio. 3.5 to 4 watts I will assume. His swr is good on the internal radio meter ( the olny one he has) and will be checked with my meter when the amp is in-line . Just needs a kick for talking to the local people he can hear on the radio. Thanks
