cobra 29 st lights?
nat19
232
4
West Virginia
I just got a cobra 29 sound tracker. The lights around the knobs and switches are out and i can't find a bulb/bulbs. Does any one now where they are at.
If all of them are out, I would start off by making sure the appropriate voltages are there. It seems highly unlikely that all of the Nighthawk LEDs would fail.
It's been a long time since I've messed with a Nighthawk radio, but if I remember correctly, you had to remove the bezel to get back to the LED locations.
Unless it is different then the one I had it has no bulbs or LED lights, it uses EL (Electroluminescent) lighting. Kind of a thin strip sandwiched between layers on the faceplate...
The one I had quit working a few months after the fellow I gave it to installed it.
I haven't messed with them but from my research, the small power supply is the part prone to failure, have seen them being sold on Egay for about 20 bucks if i recall correctly....
