Cobra HH-38WXST
Bassbug
Apr 30, 2005
19
Springfield,Ohio U.S.A.
Hello all. What I want to know is how to peak the wattage on a Cobra HH-38WXST. I need to know were the pod for dead key is located. And the modulation pod is located? I believe all I need to do is crank up the modulation? Because the Cobra HH-38WXST sounds a little flat on transmit. Is there a way to put the extra channels into the radio? Thanks Bassbug. :roll:
Hmmm. If you're using it on batteries, this will reduce battery life a lot.
Besides, it's packed like a hard-boiled egg. Just getting it back together without damaging anything isn't all that easy.
And if there's a channel mod, I couldn't turn up any mention of it.
