Combiners
If you use enameled wire to wind a combiner, the insulation-breakdown voltage of the enamel might cause the RF voltage to arc if placed directly onto a grounded copper foil surface. Some folks use teflon-insulated wire. It has a higher breakdown voltage and probably doesn't need this extra step.
I use teflon, and the ones I've seen either etch the board or use a spacer used teflon also. It makes perfect sense if you're using enamelled wire.... I guess you just can't be too safe. Thank you for the reply.
Speaking of filament chokes, not that this is my thread, but on the same vein of thought... I learned the coupling effect to the chassis the hard way. I pretty much suspend every filament choke now just off the surface of the deck. However you can do it is useful...in tube amps of course.
Reactions: Catalyst 122
