Commander 150A AB linear amp schematic?
Robb
Honorary Member Silent Key
I Support WorldwideDX.com!
Dec 18, 2008
11,432
3,688
323
Silicon Valley CA, Storm Lake IA
I have seen many of these amps floating around in my day. Used to be very common. Long ago, I had the 250A(?) model, IIRC. But I cannot seem to find a schematic for one.
Someone brought me two of them to go thru and make them work. If I had a schematic, I might have a chance. CBTricks doesn't have one, as I have looked thru their amp schemes.
Anyone have a schematic?
Thanks in advance!
Found a smoked 68 ohm resistor that I think goes to a 2N4401 transistor.
That transistor is probably cactus - along with that resistor.
The TX keying circuit?
Dunno . . .
Haven't checked the relays yet; but it sure would be cool to have the schemo for it.
Not making any money on it, just helping a local CBer/forum member because he asked for help.
Never have had a diagram for this one. I remember it for the double-sided pc board and the tendency of the foil pads to lift. Don't know if it was just cheap glue or what but unsoldering a component from one of these seemed almost guaranteed to lift a foil pad.
Not a favorite.
And a diagram would still be better than not having one.
Reactions: NZ8N and Robb
It does look very similar to the old Palomar Red Devil mobile 10/11 meter amplifier. There is no doubt that the case is identical.
I will keep looking periodically. I did see where a couple of them had been listed and sold on eBay back in 2018 but there was no link to technical specs or schematics.
Reactions: Robb
Findings:
The smoked 68 ohm resistor in one amp showed a value of 114k ohms; so it was replaced (doh!); the 2N4401 transistor was OK - strangely enough.
Found three caps (one 10uf and two 470uf's) that were marginal/bad and were replaced.
Rec Amp indicator led needed to be resoldered and now works.
Removed two finals in one amp and tested them - both good.
Cleaned off the old paste, filed them flat with a smooth flat file and re-installed them with new paste.
Adjusted RV1 pot in both amps.
Cleaned the relays in both amps; one was pretty badly carboned up, but cleaned up well (both were dirty).
Both amps are working.
DK was set to 3w on a President Grant test radio and both amps saw ~140w/pep @13.8v on a 100w dummy load.
Thanks to all who chimed in!
BTW - are those Macom branded MRF-455's transistors any good?
Or are they junk?
Both of these amp here have the original Motorola transistors in them - no problem there.
Was just wondering about the Macom output power, build consistency, and quality . . .
Findings:
The smoked 68 ohm resistor in one amp showed a value of 114k ohms; so it was replaced.
Found three filter caps (one 10uf and two 470uf's) that were marginal/bad and were replaced.
Rec Amp led needed to be resoldered and now works.
Removed two finals and tested them - both good.
Adjusted RV1 in both amps.
Cleaned the relays in both amps; one was pretty badly carboned up, but cleaned up well.
DK was set to 3w on a Uniden Grant and both amps saw ~140w/pep.
It is always awesome to hear good news!
I am glad that you got them both working.
