connex 4300-300
On the newer EPT0SSB50C echo/reverb board, changing R30 (10K) +/- ohms effects DEPTH of this time based device. It took a 2.7K ohm as R30 to make effect DRY with control just turned on. This unit now behaves as it should.
I realize this is an ancient thread but it's still relevent.
Want to give a shout out to Strykerradio....BIG THANKS for posting this specific info.
Thank you
What radio specifically are you referring to? I actually remember the 4300-300 as I owned one but hated the echo myself. It had the echo board with the potentiometer built onto it if I remember correctly. I don't remember other radios having that board but I may be wrong so as to why I ask what radio you're working on.
Connex 4600 Turbo. All the components on the echo/reverb board I speak of are surface mount technology except this R30 and a couple of electrolytic capacitors on other side of board. See attached pic. Hope this helps.
Reactions: Wildbill63
Thats good to know, thanks for sharing that for those of us that might run into that sometime. That isn't the same echo pcb that was in the 4300-300. It was also smt but much smaller and built onto the back side of the dual control pot. Was not a good sounding echo. I remember it gave that banjo effect as the first poster called it.
