Connex CX-3300HP low VCO voltage
Hawkeye351
Sr. Member
Jun 27, 2021
858
777
103
58
Got a Connex CX-3300HP on the desk today with low VCO voltage.
Cannot get the VCO voltage up to 3.20v. it'll go up to 2.19v and then drop out or start dropping back down.
Issue with radio is, frequencies are all out of whack.
10.2398mhz measured on pin 4 of the PLL.
15.23??mhz measured at TP3
Checked wires going to channel encoder, all are firm and making good connection. Checked all other connections to main board and band control, all show good connections. Checked 8v regulator, getting proper voltages, checked audio IC, getting proper voltages, checked for PLL voltage, it's present at 8.56v. Solder joints look good under zoomed in camera.
What would prevent the VCO from being able to reach 3.20v?
  • @ Catalyst 122:
