Connex echo board Installation....need help
razor
Feb 27, 2006
27
I was given a echo board taken from a Connex radio. I was wanting to install it into a Tram 201. Is this possible? If so can someone give me some help. I know the the Tram 201 runs on 110 volts but somewhere in it there should be a 12 volt source??? I looked for a web site with instructions but couldn't find a thing.
I may try to put this in a box and make it where I can use it on several radios, feeding it with my astron pwr supply.... Any one with some experience with this , please let me know. Seems pretty simple but you know how that goes. I have most of the parts at my disposal..... Just for the record. I like just a touch of echo.... an no more. For me it would be good to improve the audio of some of the older rigs. IMO.
If I remember right, the Connex/Galaxy echo boards uses an 8 volt supply. So you might want to add a resistor inline on the 12 volt supply to bring it down to~8 volts. I've seen people use 12-13 volts....but I believe 8 is correct. 73's, Pluto.
Pluto you are right the brown wire needs an 8v supply or whatever the power is color wise my echo board has brown lead for the 8v supply.
    357 has joined the room.
  • @ 357:
