Couple ?? on MFJ 259B
DXman
Yes, that's 3100 degrees F. Nine yrs of hard work.
Apr 5, 2005
1,730
1,195
173
76
West Coast - Washington
Hooked the meter to the Ped. 10K and this was the readings;
R=78 X=7 SWR=1:7
Now with my other two meters the match was 1:1. I tried moving the stinger up and down and there was no difference, this was the lowest I could get for SWR and X
My coax is RG 8x @ 14'
I then hooked up a 18 foot section of the coax that came with the Wilson 1000 and the SWR dropped to 1:3 and R=62 with X=3.
So I replaced that coax with the 14' of RG8x and using a "barrel" connector and a 6' section of the same coax the SWR dropped to 1:1 and R=52 and X=0. So I now have 20'
So now everything looks good, but here is my question; By adding more coax is this just fooling the meter?
Can I hook up just a short piece of coax (1",2" etc.) and check the antenna this way?
</p>
You can use a short piece (6" or so) but I'd set it for use with the piece of coax you're going to use. If 20' shows it at 50 ohms 0 reactance, use it.
Wm. Warlock "71 and the long black limousine in Va"
Rollingradios@aol.com
Nat. Rep for XForce/Magna Force Customer Service and Support
</p>
