CPI 2000 issues
If you have an oscilloscope you should see a waveform on pin 2, not just a DC voltage.
Like I have said I really don't know what I am doing with the scope yet for sure, but Nomad helped quite a bit here, I turned down sweep time/ div to 2 and put the probe on pin 2 on that ic I had replaced and the line rises but I really don't think it really shows a waveform I don't know. The first picture is with the probe off and I had set the line to 0% at the bottom. The second photo is with the probe on pin 2. Perhaps I need to make adjustments
I do see another thing, the 74160 ic on the far right there just gives this on the outputs
Where as the other 74160 ic outputs give somthing that looks more like this
From what I can see you do have a signal on pin 2. I just can't say if it's any good or not. It should be in the neighborhood of 4 MHz or so. Or at least that's what the service manual says.
I went back in the thread and found where the schematic and some service notes were uploaded, but not the service manual, so I'm attaching that here. It can probably answer your questions faster and more accurately than I can.
Reactions: Danzik
Forgive my ignorance as I have never had the pleasure of owning an analog scope (cool!), but what is with the bright and dark bands? Is that persistence from the phosphor or a camera artifact?
Why not adjust the horizontal scale a little to try to see the rise and fall of the actual signal? It is clear there is an AC signal there, but it is not clear what it is.
1/frequency=cycle period. If you expect to see a 4MHz signal, set the time per division close to that period so you can see whats happening.
Did you calibrate your new probes?
Reactions: Danzik
Yeah, I am new to using a scope and I need to work with it a bit and do some research in them, I will try your adjustments and also look into how to calibrate the probes because no I did not calibrate them yet. Thank you for the advice I appreciate it, this is a new ordeal for me
The dot scans from left to right at a rate that makes audio signals legible. An RF waveform naturally moves up and down way too fast to separate the ups and downs of the waveform. Makes the "luminous band" trace this way. Naturally if you speed up the horizontal time base to a microsecond or (typically) less, the actual RF waveform becomes visible. But anything with a lower frequency now gets stretched from left to right as a barely tilted flat line.
Rolling the time base knob up and down will reveal the tradeoff between seeing low-frequency stuff a one end, and the actual RF waveform at the other end of the knob's travel.
