Craig 4201
Greg T
WDX-945 (Jazz Singer) Upper Peninsula of Michigan
Sep 18, 2014
1,519
2,559
273
72
Escanaba, Michigan
Does anyone know how to increase the modulation on a Craig 4201? I can find schematics, tune up instructions, Mic wiring, but no modulation increase.
If you can trust Sam's (CB-99), R192 is the modulation adjustment and R191 will adjust the modulation meter.
There's also a pdf out there that says cut CR118 and CR119. I'd suggest just desoldering in case it doesn't work. Link thingee: https://preview.tinyurl.com/4reeud4p
Sorry, don't actually have a 4201 to confirm any of this with. Use at own risk, buyer beware, blah blah blah...
Reactions: Greg T
Thank you very much, guys. Much appreciated. I have no idea why this stuff doesn't show up in the search engines.
I cheated a bit. Looked it up in the Sam's index and then checked the relevant book for transmitter alignment. Search engine won't do that.
Reactions: Greg T
Appreciated. As I checked out the links I remembered that I have all of the Masters publications stuffed in a closet from back in the day when I was "golden screwdrivering" for the locals. ;)
