Cutting amc limiter ..BUT ONLY USING STOCK MIC Question
The only problem with replacing R124 and R126 with lower values, is that it "screws" up the ALC, the reason that it does it is because it relies on a certain impedance. I would personally put R124 back to 10k, and R126 back to 10K. Make sure R131 is a 10K, then if you want louder audio on AM, remove TR-26.
Ok I know that cutting the amc limiter can cause splatter ect especially with a power mic. But what I was wondering was what about cutting it and only using a stock mic? Would this cause splatter, Would it improve modulation on the stock mic? What is everyone opinion on this and what are your experiences on this.. The radio I was thinking of doing this on is a Cobra 148 gtl... I would prefer running a stock mic anyway cause I prefer it on sideband but would like a little more umph for AM without going to a power mic....
