D104 wiring
Heavy Metal
531
45
38
65
what is the pin arrangement for a D104 Silver Eagle K with ETS, PAD, VOX on it
These are the wire colors cable has to it:
Blue
Black
Red
White
Bare Non Coated Wire ( Sheild I guess )
Yellow
Want to know what colors to what pin on a kenwood TS-480 RJ45 Type Moduluar 8 pin plug
Which wire to which pin?
3
4
5
6
7
8
Also same for a regular D104 Silver Eagle
Both have keyer on the base plate as well
Also connected as follows and has a DC hum reported in it?
8-pin Modular (TS-480, VHF/UHF Mobiles)
Pin 3: Ground - Blue/Common
Pin 4: PTT - Red/TX
Pin 5: Microphone Ground - Black?
Pin 6: Microphone In - White/Audio
yllw/bare wire= nc
HELP lol
if I remember correctly, you should use EITHER the yellow or blue wire,depending on if you have an electronic or mechanical PTT switch.
I think I hooked black wire up rather than nc like yellow and instead of bare wire.
But reports are I have a DC hum / rf possible maybe it's black wire disconnect and use bare wire, but it has the PTT on base too and has ETS, PAD and VOX on bottom as well.
Pin 4: PTT - Red/TX
Pin 5: Microphone Ground - Shield ( Bare Wire )
yllw/blk = nc
Works ok now BUT cannot get the base to key the handle keys by not whe one presses the base part
Any suggestions?
As seen above the cord only has the following wires:
Blue
Red
Shield( bare wire )
Black
Yellow
It has no white wire... That eminents from it to connect too.
What will be the connection for the TS-480 on this model?
Need to make on his both PTT switched to work...
Thanks
