DEAD KEY CHECKING
long night
202
39
38
77
Hi to all. When I check the dead key on my radios I notice that they all go up a little and then settle down.Is that normal? When they settle down is that the actual dead key. For instance one radio may go up to about 4 watts and then quickly settle back to 2 watts.
Thank you for your help here.
Chuck Saylor
Chuck…turn you modulation off/all the way down. That will probably eliminate the momentary spike your seeing on the meter. Also are you doing this into a dummy load or your antenna? What meter are you using?
Brad
Thanks Brad. Dummy load and just radio meter on my cherokee 1000.
  • @ Hambones amps:
