I have been looking looking to install a dipole antenna for a HF station that I am putting together (hopefully very soon)
The antenna that I am looking seriously at is the Princton 80D
it is the antenna that is shown at the top of the page on this link
Associated Radio
I have done alot of looking at the property here and I just dont think that I am going to be able to flat top it ( I realize this is the prefered way to have a dipole set up and the higher off the ground the better ) ...so I am looking at an inverted V configuration for the antenna running Northeast to Southwest more or less direction...the balun will be set at 45 to 50 feet off ground ...and yes I will be running a tuner
So what I am asking is at what angle from flattop is the prefered angle in degrees to set up antenna? more or less of course....
I do know that a dipole such as the G5RV for inverted V prefered is more or less the same angle as taking a circle and cutting it into 3 equal parts or 120 degrees between the wires..
I do also realize that different types of dipoles (windoms,off center fed types have different characteristics for inverted V set ups)..so any ideas guys?
and thanks
Associated Radio
and thanks
