Would like to still find the damage done, but would also like to re-locate the DI location to a different ground or different place on the board even if I had to, weird though that it didn't do the same to my other 55vdi that works fine but you know radios are weird sometimes. I'm not sure what power choke your speaking of unless you mean the chokes coming in from the 12v power plug on the back, I've tried running the ground to case from the audio and it has to be board ground to not squeal but I wondered if being shorted to case ground from that audio plug had something to do with it, board ground was the only way to nake it not squeal. How would I "carefully" go about changing grounds from the shielded cable I have at L5 to the power choke? Again thank you handy Andy I think we're getting closer and closer to finding the problem with this. I'll go through the circuit at L5 and check the voltages at ic1 and ic2 and change L5 just to be sure, might even change ic1 and ic2 while I'm in there if voltages are off, I should have the spare parts here somewhere. I'll try to get it done tonight when I get back home.
