    Dismiss Notice
Dx2547
Discussion in 'General CB Services Discussion' started by kaos513, Feb 14, 2020 at 3:17 AM.
  1. kaos513
    kaos513 Sr. Member
    Apr 10, 2014
    2,014
    540
    Hello guys I ran into an issue with my dx2547 alignment for vco connect freq to tp6 when I do numbers jump around on tx mode but here is wierd part on tp5 alignment for vco on all bands work to adjust don't really know what tp6 does unless vco went bad ? Thanks
  2. nomadradio
    nomadradio Analog Retentive
    Apr 3, 2005
    3,220
    3,327
    TP5 and TP6 are not connected to the VCO, or any other part of the radio's PLL section. These two test points are for the carrier oscillator, 10.695 MHz plus or minus 2.5 kHz.
    This is a bit tricky. Hooking a probe to these points tends to disrupt the circuit. You could try probing the emitter of Q46, the carrier oscillator transistor. Just one problem. The tip of the probe has capacitance to ground. This will alter the frequency coming out of Q46 when the probe is disconnected. The test points shown are isolated from the crystal and Q46, but the level is really low. Only a counter with a really sensitive input will get you a reading from those.
    We use either a service monitor's receiver input or an accurate ham transceiver to 'sniff' the output from this crystal without tapping into the circuit with a probe. This way it gets set on frequency without any disruption to the setting of the trimmer slug for each mode.
    One way to minimize the disruption to your counter reading when in transmit mode is to remove the bias-test jumper (mirror board) while trying to get a counter reading in AM transmit. Stray RF from the final stage will leak into your counter probe and disrupt the reading. Removing that jumper while setting the 10.695 MHz AM carrier-frequency adjustment might fix your issue.
    kaos513 likes this.
  3. kaos513
    kaos513 Sr. Member
    Apr 10, 2014
    2,014
    540
    Tp5 works to align the radio on all bands but seem odd tp6 didn't work
  4. nomadradio
    Apr 3, 2005
    3,220
    3,327
    There is a small-value capacitor between the carrier oscillator and TP6. Odds are that your probe has too much capacitance to ground from the probe tip. This creates an AC-voltage divider that cuts the signal level below the minimum for the counter.
    kaos513 likes this.
  5. kaos513
    kaos513 Sr. Member
    Apr 10, 2014
    2,014
    540
    Thanks buddy
Share This Page
  • About Us
    The WorldwideDX Radio Forum was originally established in 2001. We pride ourselves on welcoming Radio Hobby enthusiasts of all types, while offering unbiased, informative, and friendly discussion among the members. We are working every day to make sure our community is the best Radio Hobbyist's site.
  • Like us on Facebook
  • Premium VIP Member
    The management works very hard to make sure the community is running the best software, best designs, and all the other bells and whistles. Care to buy us a beer? We'd really appreciate it!
    Donate to us!
