Eagle Tomahawk
I found your request doing a search for the very same thing. Did you ever locate a schematic for the Eagle Tomahawk? I just inherited one, but without a mic and can’t even find a picture of what type of mic came with it. I’m hoping if I can locate a schematic, it will have the pin-out and I can wire up something to work.
Thanks!
Thanks!
I think I remember seeing that radio advertised with a Uniden 6 pin mic from a Uniden 980 SSB Radio on Graigs List just a while ago. Can't say for sure but check the # of pins .
Here is what I have on the Cherokee CBS1000. I too believe it is basically the same radio. Hope it helps.
Eagle Radios ALBRECHT SS 497, CHEROKEE CBS 1000, DRAGON SS-497, Eagle Tomahawk, Intek Multicom-497,
Reactions: FlyBoy50
Yeah your correct that same radio wears several names.
