Im currently testing a 5010..it doesnt barely TX so I removed final and driver..I measured voltage at the driver base and its not stable, jumps around from 0 to 8v..traced backed to the predriver, removed it and same thing at the base pad..I furthered down to the 2 transistors right before the 3 white coils, same thing..I attached a SDR radio with a cap to the bases of these transistor and I do get the correct frecuency signal buts its very jumpy..what should I look for now? I suspect a crystal problem..
