extra channels
There is info everywhere on this radio if you search the net. Its actually a pretty simple modification. You just need the switches to install.
Another way is to get whats called a Viagra board. You can use the lo med hi tone controls on the front face for band control. This mod will give you 120 channels in 3 bands of 40. Obviously you loose the tone control feature when doing it this way. It looks very clean and stock when done. Only complaint about this mod is in a cold weather area it will drift alittle.
