Fan speed too fasssssttttt Help
Captainlee
Don't give up the ship
Apr 8, 2012
17
San Diego, Ca
Hi I have a 12 volt fan was on a car radiator I want to use it to suck the heat out of my ham shack, but it turns too fast what can I put in the 12 v circuit to adjust the speed? Thanks for responding and looking.. Cap
If a variable potentiometer will work what is the Resistance value for the pot?? and which leads do I use on the pot??
For $20 you can get a window unit from Wallmart.
An auto fan is meant to run high speed and move enough air to be useful for that application.
Good luck.
