"FAT DIPOLE" centered at 27.385. Questions.
That's about the distance between the two feedpoint terminals, but the tubes metal were about 1/2" apart inside the pvc tee. Fence rail has a turned down end that enables it to fit into each other. I put that end into the pvc center pieces. That enabled me to get the fed ends closer together.
