FL2100B cloudy tubes?
357
Walkin' the dog
I Support WorldwideDX.com!
Sep 12, 2009
1,513
889
123
52
Chilliwack, BC
www.youtube.com
I picked this up yesterday and it looks pretty mint.
Nothing overheated or charred, no mods, looks barely used.
I unhooked the HV and let the tubes burn over night.
I wanted to inspect the tubes further and noticed some clouding on the glass and was curious if I have a problem.
Pictures look worse than it is but still...
IMG_2393.JPG IMG_2394.JPG IMG_2395.JPG IMG_2396.JPG IMG_2397.JPG IMG_2398.JPG
Reactions: Sonar
Thanks.
I notice these are "round tops".
I have another matched set that are the beveled top and I can see that the plates are a bit bigger and beefier.
I'm waiting to borrow a variac before I fire up the HV.
Those tubes were most likely made by RCA or Sylvania....
Hard to replace, so treat them nice!
Run them about 500w PEP and you'll have a good working amp for a long time.
Amp looks very clean...well taken care of, by the interior pics.
Do your self a favor...Don't use it on AM...
All the Best
Gary
Reactions: 357 and Sonar
http://www.bcdxc.org/fl2100b_man.pdf
Good info if you did not get the manual...and some useful tube data at the end...
When reading the specs note that power is rated at INPUT not output...
so figure 50% duty cycle equals max 600w PEP output...SSB
Also rated INPUT on AM service is 600w....so max 300w PEP output...
That why I said do yourself a favor...don't use it on AM...
Enjoy All the Best
Gary
It was originally a Taylor T160L designed for AM modulator service in 1959 but with AM dropping rapidly in ham and commercial usage they couldnt find an OEM buyer. The BCB TX's werent Taylor users and stuck with RCA, Eimac, Westinghouse, Amperex which were well known and reliable.
United Electronics in NJ bought the design in 60-61 and called it the 572, not to be confused with the 1930's DeForest version where the 5 identified the manufacturer and the 72 was the actual type.
UE could not produce them fast enough and partnered with Cetron in IL and the 572A was UE with the round top and 572B was the shouldered glass Cetron.
You will also find some round top Cetrons which were actually built by UE when Cetron was overloaded with orders. Both private labeled for others such as GE, Raytheon, Waters, Amperex, RCA, Dentron, and maybe others.
https://www.eham.net/ehamforum/smf/index.php?topic=113259.40;wap2
Looks like I got 3 different cetrons...
Nice looking amp. Nothing wrong with Cetron tubes BTW. they are actually very good. Like Gary said above don't push the amp too hard and do not expect more than 600 watts pep out on SSB and you should be fine.
Reactions: 2RT307 and 357
Well since I have no hope for a variac and they are $$$ on ebay, I've been bringing the HV up with a 5K resistor via the 425V tap.
the volts were 1000 and left it that way a few minutes.
No blue glow, no arcing, no rises in temperature on the caps.
Now I moved over to the 620v tap for 1500v, still good.
Will report back.
  • @ Spanish:
    Where do i upload schematics
  • @ ShadowDelaware:
    Who do I contact for a name change. I put in for it over a year ago and it says still under review.
