ft1200dx and interface
ahasverus
Dec 2, 2011
77
3
18
i try in vain to send/receive rtty
i have interfaces
rigblaster advantage
yaesu scu-17
think to use fldigi software
use windows
the cables , i can make them
yaesu gives me the cable ( ct packet interface)
one side 6 pin other side blank
(pins: tx audio/ground/ ptt/ rx date 9600 bps/rx date 1200bps/squelch)
i have the mini jacks 3mm stereo
gnd/fsk/ptt
and
gnd/out/in for audio
i don't see how to hook up the pc with the rig
or the scu-17
which port to which port , which cable
i should be much obliged if someone spent some time to tell me how to do
on3bm on qrz.com
thank you
...i don't see how to hook up the pc with the rig
or the scu-17
on3bm on qrz.com
thank you
read page 5 of the scu-17 manual http://ri.search.yahoo.com/_ylt=A0L...X700.pdf/RK=0/RS=SXe.wgegK0hP5sGbPhyKNZaqAW4-
connect the supplied cable USB type "b" male end to the scu -17 and the USB type "A" end to the computer
install the virtual com port driver BEFORE attempting to use the scu-17 or widows will load an incorrect driver
