With the version 1.2 software upgrade it looked like the FTM-350 could finally be used as a input to UI-View.
After some messing around, I got it to work. I get a error message on start-up that the TNC is not responding, but that makes sense.
These are the settings that I have so far.
FTM-350
E-16 speed 4800
output- packet
E-17 APRS- sub-band
DATA- sub-band
These may vary depending on how you have your APRS set up
UI-View Comms setting
Baud rate- 4800
Parity- None
Comm Port- 1 (check to see what comm port you cable is plugged into)
Data Bits- 8
Stop Bits- 1
Hand Shaking- None
Host Mode- None
TNC Type- TNC2
Receive only- checked
Seems to work fine once it is up.
Hope this helps
Ray
FTM-350
E-16 speed 4800
output- packet
E-17 APRS- sub-band
DATA- sub-band
Baud rate- 4800
Parity- None
Data Bits- 8
Stop Bits- 1
Hand Shaking- None
Host Mode- None
TNC Type- TNC2
Hope this helps
Ray
