galaxy 66
tim48601
Nov 4, 2008
When i turn on my galaxy 66 it goes slowly thrue the frequencies untill it gets to the channel i have selected. None of my friends galaxy have this problem. It also will start drifting frequencies and i tap it and usualy goes back to normal.
Anyone have any idea what to do to correct this problem?
I would start by checking for bad solder joint or another thing to look at is the crystals. I had one that started doing that then slowly got worse turn out to be a bad crystal alot of galaxy's will drift unless you realign it with a scope.
Yeah, a bad solder joint is a likely culprit. Check the solder joints arount the PLL chip, the crystals, and also the LCD display. It could also be a bad crystal.
  • @ Mark Malcomb:
  • @ Naysayer:
    I’m
  • @ kingmudduck:
