galaxy 959 meter lite doesn't work
anixon
Jun 11, 2006
52
nj
959 there was no bulb in it. so i looked at the cbtricks web and found pcb ept55v-51z board which looks just like i got. but where they are showing bulb goes. i try it and no go with 12 volt bulb. there is no solder at those little holes either. could it be one of the resitors burn out before it reaches this point. any info thanks
about that your right on red to switch and black to ground. BUT if you look at the pc board behide the meter ,there is no switch on the board. JUST THOUGH I LET YOU ALL KNOW.
