galaxy dx 88
bluecurt63
Jun 17, 2014
31
6
18
ive got a galaxy dx 88 and the frequency counter don't work. Ive changed r37 and the frequency counter pcb,checked the power , does anybody know anything else.
A Galaxy 88.. start looking for poor solder joints. Mine had dozens. No Tx, No RX, default freq, no meter, intermittently working.. I went over it with with a spool of solder and a fine tip iron and retouched the solder on everything I could get to.
I was shown a trick of using a plastic ink pen casing as a probe and start pushing on solder joints with the power on. You'll find issues that way. even a light flexing of pushing on the board in areas narrows down issues.
I agree with poor solder joints. Many Galaxy radios I've worked on were either only slightly in need of some solder joint repair - or sometimes half or more of the entire board. Same goes for the freq display board too. Bring patience; you'll need it. The freq counter itself may need recapping - seen that a couple of times. Think I still have a couple of 88's here that I had to do just that . . .
Ah, "counter won't work"?
As in, just won't light up?
At all?
Is this the old version of the counter that's 2/3 the width of the radio?
Or the post-1995 version that's less than half that size?
Big difference inside.
Big difference in where to look for the fault.
Reactions: NZ8N
As well as check to make sure all the headers that arrive from the front panel thru that harness then onto the main board - are routed to their CORRECT position and not twisted around or placed in wrong positions.
You can easily wind up going thru Frequency Counters, several times over, due to a bad header that got swapped...
Give Credit where Credit is due - see attached for some help in that wiring spaghetti mess
Reactions: NZ8N
  • @ Spanish:
    Where do i upload schematics
  • @ Catalyst 122:
    Who do I contact for a name change. I put in for it over a year ago and it says still under review.
