Galaxy DX-949
NY 38
May 5, 2022
12
3
13
80
good morning ! I have a galaxy DX 949 that receives, transmits fine but the meter is non functional. the needle is all the way up no movement at all. how much of a job is it to replace the meter or is there some adjustment ?
Reactions: Rwb
Super simple replacement if needed. Remove all the knobs, the 4 screws holdings the actual bezel (not the ones holding the front plate) slide off the bezel and you're to the meter. On the older ones the meter was adhered to the metal plate but most recent ones have only clear tape holding it in place. 2 wires to solder, then adjust new meter to agree with what it needs to show.
Reactions: Rwb and Crawdad
