Im currently working on adding in some extra channels on a Dx-959 using the good 'ole P5 and P6 method. I dont wanna hack up the outter portion of this radio as it is brand new and is still all shiny and pretty haha. So instead of using two switches mounted on some random part of the chassis as the mod calls for, Id like to find a way to install it using JUST the Noiseblanker Switch. Since this switch is never used on any of my CBs I would like to disable it and wire up the P5 and P6 mod right through that switch.
So here is my obvious dilemma: Rather then having two SPST switches mounted in line between those two wires....id like to use this one 3 position switch to obtain all 4 positions needed for the mod to work. I cant, however, logically think of a way to make 4 positions work with a 3 position switch! I need to obtain:
Open Open
Closed Closed
Open Closed
Closed Open
Ive heard of it being done but can find no details of it online. I do have the option of using another switch upfront like the PA switch or Tone switch which are also never used, but was trying to keep it to one switch rather then two. Any ideas or comments?
Open Open
Closed Closed
Open Closed
Closed Open
