I have a dx66v2 that keeps popping the fuse when you key up the mic. I’m not that tech savvy but have already replaced the polarity diode that is generally the culprit. I’m looking for the schematics for this radio so I can maybe start to learn how to do the troubleshooting. Also any help would be appreciated.
update: when there is nothing hooked up to the coax connector (I know you shouldn’t do this, I thought my dummy load was hooked up but realized after the fact it wasn’t) the fuse will not blow when you key the mic but as soon as you hook up either the antenna or a dummy load and key up, the fuse blows.
