I acquired a Galaxy 99v off an online site and it is working great in every mode and does work on lsb with proper power output and is on freq on center slot,but the problem is on lsb only you can be on channel 38 on the channel indicator but the freq counter says you are on 27.405 and that is where it is on 40 .The radio has almost no slide on lsb with the clarifier so it seems on lsb it is maxed on the unlocked clarifier but in every other mode am and usb everthing is spot on and it slides aright and displays right..Lsb work with proper power but I would like to get it right please ,give me some area to look at to fix the lsb (slide) (channel) issue.Thank you in advance Jef
