Galaxy Melaka No am Mod
harlyworkr
New Member
Nov 2, 2017
7
64
I have never seen this one b4. I have no modulation on Am only. I have it everywhere else including lsb, usb, cw, pa and fm. Any suggestions? This is driving me crazy
Thanx
Mike
TR51 in this radio is #A1012 Which is a
Silicon Complementary Transistor Power Amp Driver, Output, Switch. Is this what you are talking about?
Show me photo of mainboard, element side.
That transistor have 12V from power socket on emitter and collector goes to driver/finals.
That is the one you found.
In AM, on collector you should have circa 6-8V, SSB 13.8
When in am is full power supply voltage, it is shorted.
Mike
Do you have a wattmeter in the coax line with this radio?
It would be helpful to know if the carrier is jammed to 15 or 20 Watts on AM.
This model doesn't have a carrier-power knob on the front. Seeing what happens when you turn that knob on the other models is a helpful diagnostic clue.
But this radio doesn't have that.
Do you know where to find the type number for the printed circuit board? It will start with "EPT3600", followed by two more digits and a letter.
Knowing which circuit board is in your radio could be helpful, as well.
Very good chance that sp5it has the root of the problem already itentified, especially if the AM carrier is over 12 Watts.
