GALAXY SATURN Power question
Crambone
I Support WorldwideDX.com!
Jan 22, 2019
563
175
53
57
so I picked up a Galaxy Saturn that has a power switch on the back, looks like it just killed the fan and power at J22 too the amp. This is ok it’s working as should.
The issue I’m having is dead key on low and high power is set to .5 watts. I need around 4 watts on low so I can use with my amp.
Any idea what adjusts low, high, peak, modulation?
Umm, this wouldn't be a Galaxy Saturn TURBO, would it?
That one word "turbo" makes it a totally, totally different radio from the one they sold with 'just' the name "Saturn" on it.
Okay, so if it's a Turbo, you are seeing just how little carrier power is needed to fully drive the internal linear.
If you turn up the radio's trimmer control that sets the max carrier higher, you run the risk of blowing out the linear and/or power supply.
If you forget to turn down the carrier knob before you turn on the linear, you could end up with a 120 or 140 Watt carrier when the linear is turned back on.
Won't blow out the radio right away. Just not a wise thing to set up to happen.
So, just what kind of amplifier do you have that needs a full 4-Watt carrier? Can't see how it matters, since the barefoot side of this radio is throttled back to no more than about 16 Watts peak. That's all the internal linear can handle, so that's how the factory sends it out. Any linear that "needs" a 4-Watt carrier won't be impressed with 16-Watt voice peaks.
We did work out a setup that mounted a trimpot on the side of the linear "suicide" switch. Requires a two-pole, or "DPDT" switch. This trimpot would get placed in line with the trimpot on the radio board that sets max carrier. When low side is selected, the radio's internal trimpot will usually get you 3 Watts or 3 and a half. The trimpot on the side of the switch is shorted by this side of the switch. When you select "high" and turn the amplifier back on, the short across the new trimpot is removed placing it in line with the radio's carrier trimpot. The new trimpot is used to set a safe max carrier for high side only.
Whew! Takes longer to explain than to install it.
I'm pretty sure we have some pics of this solution. I'll see if I can dig them up to post here.
(edit)
Whups, just noticed you said the switch shuts off the fan and the linear both. This means you already have a 2-pole switch. I suppose our 'extra trimpot' trick would require a 3-section switch.
Oops.
No just a regular Galaxy Saturn. I’m using an Elkin Amp and Ray told me to drive it no more than 5 watts dead key and swing is ok. I just had him service the amp and when he showed me it working he drove 4 watts and swung 14 into it.
The issue is with the Elkin not seeing a couple watts it keys on and off a lot.
If the Elkin has a tube keying the relay, that will make the full carrier power necessary. Tube-type keying circuits are usually not very sensitive.
So, if it's a regular Galaxy Saturn, just what is the switch connected to? No linear built into that model. VR13 should turn up to a 4 Watt carrier no problem.
" so I picked up a Galaxy Saturn that has a power switch on the back, looks like it just killed the fan and power at J22 too the amp "
This part of your first statement suggests you have the Saturn Turbo with the built in amplifier. If that is not the case what did you mean by this statement?
OMG don’t shoot me but I gave some very wrong info! I’m using a RCI 2995dx, I’m not sure why I thought Galaxy Saturn! I just sold that radio to a friend and my Fibromyalgia is affecting my memory. I feel like I’m loosing it at times, I think it’s sunsetting memory the longer I’m awake the worse it gets. So yes it’s a RCI 2995dx.
