galaxy33 troubles
bluecurt63
Jun 17, 2014
31
6
18
ive got a galaxy 33 hml, the tx/rx light will not work,it has no receive or transmit.tr 30 has no power ive replaced tr 38 -36-37 with no luck anybody got any ideas
tx/rx light have nothing to do with PLL
8V is missing. Than we can look for more to fix.
Really? No TX light is typical of PLL unlock due to open circuit. Yes it could be the 8v rail/regulator is dead; but first blush would be to test the PLL/loop osc.
he needs to check to see if he has power at the PA AM switch. even see if the PA works as it should for starters. could be just a dirty connection at the switch. so many things can cause this. since it has been 2 days since it was posted he may not even come back.
I am wondering if the meter light and Led for channel read out is working.?
yes meter light and led is working.i changed the pll too still the same thing.the pa is working though,im missing something
check for bad solder joints around the audio ic, 10.240 crystal and the vco area. bad joint can cause a dead radio if the vco is not running. make sure you have voltage leaving the pa cb switch in the cb mode.
