Ken: Was great hearing you again! BOOMING Sig from your way this morning on 75m. Guess my new W8JK antenna at 40ft seems to work OK off the sides also....
Great Audio from your rig also Ken and the SB1000 was punching here in Indiana. I would love to find one of those to convert for 6m...
Hope we can work more often....I am on same freq. from about 4:30 am to 5:30 am almost every morning....
Well back to the bench to do some more work on the 4-1000a amp. What Tank Circuit Coil configuration did you use, that made her "Tough to Tame" on 15 and 10m's? What Bias design did you use? 50K 10 watt switched through CT filament xformer used on several circuits I have reviewed (that's what BTI used also)....But wondering if that is the way to go with the 5K B+ , my supply will produce?...
All the Best 73
Gary
All the Best 73
Gary
