gound noise
  • Thread starter Thread starter big dady audio
  • Start date Start date
I used the snap on type, Radio shack and other electronics places carry them. Radio shack's prices are a little high, though. I just snapped a couple over each plug wire, and lined the coil wire with it.
</p>
6 coils!!!! YIKES!!! <img src=http://www.wwdx.org/smilies/posticon28.gif ALT=":28"> <img src=http://www.wwdx.org/smilies/posticon28.gif ALT=":28"> <img src=http://www.wwdx.org/smilies/posticon28.gif ALT=":28"> <img src=http://www.wwdx.org/smilies/posticon28.gif ALT=":28">
Man, that sounds like a project. Maybe you can just wrap the whole engine compartment in a few wraps of copper foil and call it good. <img src=http://www.wwdx.org/smilies/posticon46.gif ALT=":46">
That's when you just go buy the Clearspeech speaker. It's not the end all solution, but it really does work pretty good.
</p>Edited by: <A HREF=http://p067.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=moleculocdx363>MoleculoCDX363</A> at: 1/19/05 7:25 pm
From Positive to Negative, as close to the pump as you can get. You might have to play with the value of the cap a little, but that's really all there is to it.
</p>
</p>
noise
i have had the same problem with my wifes hyundia ihear a whine only on the tx when we r movin and it changes with rpm i put a noise filter inline with power leads all ground are in same place as the alternator and batterys .Ihear the noise with antenna unpluged but onlywhen i tx none on rx only thing it could be is plug wires but they were replace not too long ago???? i 'm strumped people tell me they here the wineing noise during my tx as well :?:
  • @ heartbreaker3473:
