Ham mobile antenna
  • Thread starter The Virginia Rebel
  • Start date
T
The Virginia Rebel
Guest
Can you put a dual 2 meter/70cm antenna on the same mobile roof with a Wilson 1000 cb antenna? Would there be any problems? Thanks
</p>
You mean two Mag mounts? Sure you can do it. Just don't put them too close...offset them a little or something... I've seen Jay in the Mojave do it on his truck. Maybe he can chime in and tell us if he's noticed any wierd signal pattern.
</p>
My Tow truck has the company UHF, Wilson 5000 and a Comet VHF/UHF all within 18 inches of each other with NO PROBLEMS. Even when I was running 900w out of the Wilson.<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)">
Hot Rod Lincoln -Dancing around the World ! ...... CDX948 Central Texas, - Hook948@hotmail.com[img]http://deephousepage.com/smilies/AR15firing.gif[/img]</p>
On my Thunderbird I run A BIG Coil 10/11 Meter antenna in the center(middle)of the trunk, and a Comet Tri bander(2/220/440) up on the lip of the trunk in the center. No problems. On the toyota I have a 1/4 wave Fiberglass whip on one rear fender on a ball mount and a CG 144 2 meter antenna on a ball mount on the other rear fender(looks like goal posts<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> ) with a 440 trunk lip mount in the center of the trunk.
It all works well.
CDX 339 Radioactive
</p>
