I use HRD but I wish they would spend some time speeding up the thing. I often use it with NAP3 panadapter and would like to see what they do for panadapter functionality. But I need it to support the K3, not Icom
You"ll still need an IF tap or other way to get the signal.
I been using HRD for years and I'm happy with it. I simply use SDRPlay with the free SDRUno software which I can run along with HRD simultaneously. My Kenwood TS590SG already is setup with a usable RF tap by patching into the Drive output jack and a menu setting determining the jacks output source.
Other radios without an easy IF out can use an ELAD switch box like I use for my Icom IC-7000 or I see MFJ makes a switch box (MFJ1708SDR). Otherwise an internal IF tap will have to be performed inside the radio.
I guess for convenience, it would be good to have a panadapter integrated into HRD for all radios, but for now I like SDRUno and SDRconsole which are both free!
Here's a pic of how I run HRD logbook/DX Cluster and Kenwood ARCP, with a panadapter from SDRUno. (I also use a virtual serial port software for unlimited serial ports along with the free Omni rig software to be able to accomplish this)
